Old 12-03-2010, 01:51 PM
drhntrrmw's Avatar
drhntrrmw drhntrrmw is offline
Default Head Light Panel & Stock Tires
I have a 100 and it appears that the head light panel from other narrow frame models will fit my 100. Is that true??
Also, are there company's that sell reproduction stock tires or tires that are similar to the stock tires?
Thanks all,
Rob
Old 12-03-2010, 02:50 PM
mmzullo mmzullo is offline
I took 1 out of a 1x2 series and it didn't fix the 100/70's. The panel was a little bigger. Im sure you can make it fit.
Old 12-03-2010, 05:02 PM
All of the NF headlight panels are unique to their own series. The 1x2/3 panel could be made into a 70/100 panel by cutting off the lip on the bottom, but instead of destroying a part that is no longer available, I'd sell it and get the correct one for your 100.
The 1x4/5 and 1x6/7 panels will interchange with each other but look different.
