Old 11-21-2010, 07:57 AM
Wayne Wayne is offline
Default leaky carb
My 108 carb has been leaking slightly for a while, just a steady occasional drip, enough that it smells...seems like its coming from around the bowl, but its kinda hard to pinpoint the source precisely. Someone said I need to rebuild, which I really dont want to do until spring-it runs fine, I just dont like the garage stinking like gasoline. Any suggestions for holding me over till the snow melts?
Old 11-21-2010, 09:08 AM
jeffscub's Avatar
jeffscub jeffscub is offline
your 108 should have a fuel shutoff valve under the tank. if it doesn't, then purchase you a shutoff at your local lawnmower repair shop. a carb rebuild is very quick and easy to do, if you follow the manual, it should just as good or better than before and with no gas leaks. hope this helps. jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 11-21-2010, 09:54 AM
A carb rebuild is very quick and easy...no need to save it until spring.
Old 11-21-2010, 10:13 AM
I can screw up anything, and with snow to plow almost every day I can't take a chance...I'll use the shutoff (my gawd, how dumb can I be? Please dont answer...) until I feel confident I can do the rebuild right...
Old 11-21-2010, 10:19 AM
Wayne if you follow Matt's guide during the rebuild you'll be fine. Do a read thru and if you don't feel like you can do it take it in and have it done. It's a fire hazzard is it is now so please don't take that risk.
Old 11-21-2010, 10:20 AM
jeffscub's Avatar
there were two things that i never understood, first was carbs and the second was women. i finally rebuilt a #26 with the instructions you can find on this site (of course, matts' instructions are very correct and easy to follow) and now i can do them without the instructions. i do tend to forget how to set the high idle and so forth, so i have to resort back to the manual for that. and being on my second marriage, i am REAL close to figuring out women!!!! LOL !!!!!! seriously though, with matts' "how to" guide, you can do it!!! have faith my brother cuber!!!! jeff
Jeff
Old 11-21-2010, 11:07 AM
Mizar N68X Mizar N68X is offline
The guys that build carbs also make manuals for them. EASY!!!
Too bad we can't download the manual for women!!!
Old 11-21-2010, 11:17 AM
jeffscub's Avatar
:biggrin2.gif::biggrin2.gif:
Jeff
Old 11-21-2010, 11:51 AM
Great, you know I was going to ask about women next but I'll read the carb thing first.
Old 11-21-2010, 03:02 PM
The best advise I ever got about women....
"Do not try to figure out what a woman wants!"
Because.... THEY DON"T KNOW WHAT THEY WANT!!!
Back on subject.
Why don't my fuel shut off work?
Even when I remember to shut the fuel off, the tank is empty next time I try to start them and I can see where fuel leaked down the side of the engine.
