Old 10-26-2010, 07:25 AM
cubby123's Avatar
cubby123 cubby123 is offline
Default Reverse Cub
My cub will only go in reverse and I cleaned up the relief valve and got it unstuck. when I push it forward there's no resistance but there is when I push backwards and the wheels stop. Does it just need a filter changed and new fluid. Or is this a common issue to cubs? Thanks
if you want a real tractor, you need a CUB CADET!!
Old 10-26-2010, 09:43 AM
If the pin came up, the release valve may still be stuck inside. Switch them and see it goes forward but not in reverse.
Old 10-26-2010, 09:58 AM
cubby123's Avatar
hmmm ok
