Old 05-13-2009, 07:35 PM
tubbyfirefighter's Avatar
tubbyfirefighter tubbyfirefighter is offline
Default Relief Valves
Will the relief valves of a non ported pump work on a ported one? Thanks in advance
I'm not fat, I'm just fluffy
Old 05-13-2009, 08:04 PM
If you're talking about the forward/reverse relief valves, then yes, they are the same.
Old 05-13-2009, 08:10 PM
jcrews's Avatar
jcrews jcrews is offline
I'm certainly no expert(especially after the last week) but I don't think the valves are any different it's just some ports were'nt ported and some were for lift option
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
Old 05-13-2009, 09:11 PM
Matt, the valves that i am referring to are the two in top of the pump, every pump in ebay dosent come with them and some look different than the ones on mine, i was just wondering if they were interchangeable in case i bought a ported pump
Old 05-13-2009, 11:24 PM
murphycc
Guest
Posts: n/a
Yes all the same.
Scott
Old 05-14-2009, 07:50 AM
Tubby:
Whether the pump is ported or non-ported....the valves are the same for both applications.
NOW....there is a difference in the Relief Valves. See this in our Technical Library Section... Valves
The manual and automatic type are interchangeable.
