Hey team
Had a lot of wiring problems on my 2072, most resolved but now; Occasioanlly, more than not, she wont turn off when the key is turned to the off postion Any ideas ? Thanks |
Sounds like the key swtich to me.
Nope already did that
I had an off topic tractor that did that and I discovered the smell red wire that connected to the solenoid had come unhooked. Don't know if that had anything to do with it or if it was a coincidence.
I don't have a diagram for that model but I would guess that there is a relay that kills the magneto that might be going bad. The way the magnums work is they ground out the magneto to kill the engine. Something isn't doing that.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
Make sure there is zero ohms resistance between the Ignition Switch Case and and the negative Battery Terminal.
Roland thanks I;ll check tonight - what is there is resistance ?
Make sure the kill wire going to the mag is actually grounding when the switch is off. I suspect the kill wire is broken or has a bad connection or something.
YES.... In addition, make sure there is zero ohms resistance between the Crankcase of the M-20 and the battery negative terminal.
Thanks guys not sure where that wire is at becuse I dont see it on the wiring dia. but I search
