Old 09-19-2010, 11:00 AM
tinkerin tim tinkerin tim is offline
Default VR repair-where to find this fuse material?
The right side of this photo shows a gap that melted away causing an open circuit. Does anyone know what this material is and where to buy it? Thanks.
link.http://www.onlycubcadets.net/forum/a...1&d=1284873191
tt
forum said I can't download the photo again. You can see it on page 2 of "149 only has spark when key is turned off" I don't know how to provide a
Old 09-19-2010, 11:14 AM
Originally Posted by tinkerin tim View Post
forum said I can't download the photo again. You can see it on page 2 of "149 only has spark when key is turned off" I don't know how to provide a link.
You can repost the image just rename the image and repost it here on the site.
1st image named VRphoto
Rename to VRphoto1
and repost the image.
Old 09-22-2010, 10:36 AM
NealC NealC is offline
Tim,
Before you try replacing that wire, you should figure out what caused it to melt in the first place. The voltage regulator itself could be at fault, in which case, you take the chance of burning up your wiring harness (or worse) by trying to fix something that should be replaced.
Old 09-22-2010, 11:56 AM
Have you tried your local generator shop? Personally I don't know but that would probably be one of my first stops.
Old 09-22-2010, 03:48 PM
Talking What caused link in VR to melt?
Neal,
This link melting is the result of switching the B and F wires when you hook up the VR. Go ahead, ask me how I know this, lol.
In the meantime, I unwound a wrap from the little post at the top to close the gap and sort of rigged the two pieces together with a small glob of solder. Hopefully that will hold up for a while until I get to the local motor repair as Yosemite suggested. Thanks I'll report what I find in case someone else goes braindead and hooks theirs up wrong. Later.
Old 09-22-2010, 05:26 PM
CMA's129's Avatar
CMA's129 CMA's129 is offline
do you know how many amps it is? Mopar products all use solder in fusible links you can get them at any parts store but they are usally on those spinning racks as you come in the door. At my local NAPA I belive that the brand name is HELP! They come in a pack of four or five different Amp ratings and are color coded.
"Good Dogs Never Live Long Enough!" Casey Angeletti
