Old 08-12-2026, 05:35 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default Strange Lurch on the 1772
No, I'm not talking about the Addams Family..... My 1772 has started some strange behavior BUT only when it is first run after startup while it is still cool. After I have been mowing for 15 - 30 minutes, the problem disappears. When I stop and then start to move forward, the tractor lurches as if I moved the control forward a lot. In some instances when I have the tractor near an edge on the driveway or street, the tractor starts to jog between forward and reverse. I usually have to move the control a little more than usual to get out of that area, then the jogging stops. Once warmed up and hot, the issue goes away. Last year, the relief valves started leaking. I had them rebuilt, but I seriously doubt it is connected in any way.
Thanks,
Frank
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 08-12-2026, 08:39 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Possibly in need oil and filter change?
Loose, dirty or out adjustment linkage.
Plow blade
#2 Cart
QA36 snowthower
Old 08-13-2026, 04:23 AM
I had something similar happen on my 982 and I found a broken spring on the hydro damper plate assembly.
Old 08-14-2026, 05:08 PM
FrankF3's Avatar
Thanks, I'll start with checking the spring as it is still the original. Just to be sure, these are springs 932-3012 and 932-3013? if I find they are ok, then change the filter and oil. The linkages don't feel sloppy so I hope it's one of the other.
Old 08-16-2026, 08:13 PM
Cubcadet782desiel Cubcadet782desiel is offline
it happend on my 782d if I am understanding you correctly I changed the fluid and filter and its better. when i first start it it is sluggish until its ran for a couple min hope it helps.
Old 08-17-2026, 07:42 AM
johnwd98 johnwd98 is offline
I would check the level of hydraulic fluid before changing it. The spring on the damper plate may be broken but also the damper plate itself can be badly worn so a new spring will not completely solve the problem.
