Old 08-10-2026, 12:09 PM
Rjh1641 Rjh1641 is offline
Default Gt 2550 Fuel Issue
Good afternoon all. I have been dealing with an issue on my 2005 gt 2550 with a kohler ch23 engine. i bought this machine used last year and have been working out the bugs. The issue i am having is the fuel pump runs out fuel. I have taken off the fuel tank cleaned it drilled out the nipple and all new fuel line. I have the insulation on the fuel line where it comes up to the fuel pump. Replaced the valve cover fuel pump with a genuine kohler pump, and new fuel cap. I can run for about an hour or so and it basically runs out of fuel. I take the line off the fuel pump and it lower it to the ground and gas eventually runs out so no blockage i assume. Once i get fuel back to the pump it will start and run sometimes it stalls again and i have to repeat taking off the line. Any advice would be greatly appreciated as i can not think of what i am missing. Thank you!
Old 08-10-2026, 01:36 PM
There are two nipples.... in the tank and on the pump that is.
Up to 534 and counting...
Old 08-10-2026, 01:48 PM
ironman's Avatar
ironman ironman is offline
Check that the vent in your fuel cap is not clogged.
(you can try mowing with the cap slightly loose to confirm)
Old 08-11-2026, 08:34 AM
I have tried running with the cap loose and it does the same thing.
Old 08-11-2026, 11:25 AM
Are the hoses connected correctly?
Old 08-11-2026, 12:30 PM
Hose are on correct i double checked
Old 08-11-2026, 01:13 PM
Filter on correct, or the correct one?
Old 08-11-2026, 02:28 PM
i had a generic filter on and it was flowing correctly, i switched to a smaller briggs and stratton filter because i read that it had less restriction.
Old 08-11-2026, 02:47 PM
I would think there may be an issue with the carb needle, or float set too high.
Old 08-11-2026, 03:06 PM
Would the float being set to high cause the fuel pump to be empty? when it stalls there is no fuel coming out of the pump until i take off the lower line and get it flowing again
