Old 07-25-2026, 07:52 PM
Cubcadet782desiel Cubcadet782desiel is offline
Default oil light on a 5252
so the other day I was grading our driveway with a 6 foot landscape rake on the back and it was dark I noticed the oil pressure light came on but I wasn't very bright it is so dim you cant tell its on in daylight the engine still sounds normal and has a good oil level with no gas in it mine has the 25hp Kohler command the switch is dim when the key is in the on position with the engine off as well is this a bad oil pressure switch or bad wiring? thanks,
Old 07-26-2026, 02:01 AM
Ozcub's Avatar
Ozcub Ozcub is offline
Does your engine have the Oil Sentry ?
Any signs of oil leakage around or under engine ?
My first course of action would be to change oil , you do not mention if it was full you just say it has a good level
Old 07-26-2026, 05:19 AM
It looks like your machine has a few wiring harness plugs that could be an issue. I'd pull them apart and make sure they have good connections. I'm not a fan of oil lights, I'd put an oil pressure gauge on it.
Here is the wiring diagram for your machine.
https://www.ccpartsnmore.com/cub-cad...ing-schematics
Old 07-26-2026, 06:06 AM
green407's Avatar
green407 green407 is offline
Check all of your electrical connections, and for oil leaks first.
But put a known good mechanical gauge on your unit and double check you have good oil pressure.
128 X 2, 129, 149, 1250, 1450 x 2
Old 07-28-2026, 10:03 PM
it was changed last fall and there is no oil leaking around the engine it is also full it says it has the oil sentry on the valve cover
