I replaced a 197253 deck belt recently and started wondering about something. Most catalogs list the same OEM number, but some publish slightly different specs for what should be the same replacement. That made me curious whether anyone has actually measured a genuine OEM belt against a few aftermarket versions after they've been run for a season. While checking compatibility I came across this OEM cross-reference page: click here. Has anyone here ever measured actual belt width after a few hours of mowing, or noticed one brand sitting deeper in the pulley than another?
Belt width and length have standards that are set.
An inexpensive belt,or a "will fit" belt will not last as long as an oem belt That said, a good quality aftermarket belt will also last. Just off the top of my head, Goodyear "insta power" is a quality belt, there are others,but not cheap scamazon or local hardware belts. Some of the best/long lasting belts I've had over the many decades were made for John Deere, cub and Scag, if you are needing a belt for a furnace blower, yes a local ACE or other hardware belt is fine. If one needs a belt that is doing 1/4 twists or back side idlers, and high heat like most lawnmowers, you get wht you pay for. Also a belt that has grey wiskers that has been in a warehouse or on a dealers hook for many sesons are like putting 10 year old "new" tires on your vechicle, most of the "good" has evaporated over the years. |
I recently bought a replacement for an original 1970's motor belt for my GE electrack tractor with a Mcmaster Carr belt. I need to figure out the proper dimensions for all the oem belts my tractors use and I think going forward I will order belts from them because they have quality belts meant for commercial and industrial uses.
Maybe they arent quite the durability of IH belts meant for outdoor equipment use, but I think they're better than the bottom tier of cheap hardware store or amazon supplier belts.
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller 70- 38in deck, 42 inch deck GE E-12 Electrak- front mount mower, snow plow |
