Old 06-28-2026, 10:56 AM
jarpajack jarpajack is offline
Default Cub Cadet 2182 Crank No Start: Disengage PTO Light on
Hello,
My 2182 cranks but won't start, light for disengage PTO is on. I've tried unplugging the switch on the dash and the PTO itself
This one also has rear PTO.
Any ideas of where to look?
I'm anxious to get to use this thing. I've fixed the hydro leaks, changed the hydro fluid, oil and the filters, all new pullies and belts for everything, new ignition switch (yes it's worked since installing it), new thermostat, coolant.. needless to say I want to use it and not just work on it
Thank you!!
