Old 06-07-2026, 01:25 PM
Jdolph85 Jdolph85 is offline
Default 1450 drive shaft question
I had the driveshaft out replacing the fan and rag joints. Now I am almost positive the double rear rags were installed like the front rag to the engine but now im doubting myself.
Does the rear coupler bolt directly to transmission coupler? (Through rag joint) or are they offset?
Old 06-07-2026, 01:34 PM
green407's Avatar
green407 green407 is offline
Off set 90 degrees.
As can be seen on page 2-39B of the manual
https://s3.us-east-2.amazonaws.com/c...ervice+Man.pdf
128 X 2, 129, 149, 1250, 1450 x 2
Old 06-07-2026, 01:36 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Why.... the rag joint has 4 holes!
Plow blade
#2 Cart
QA36 snowthower
Old 06-07-2026, 01:58 PM
Originally Posted by green407 View Post
Off set 90 degrees.
Thank you!
Old 06-07-2026, 03:39 PM
green407's Avatar
Your cynical is showing
