Old 05-20-2026, 01:00 PM
Stargazr Stargazr is offline
Default Cub Cadet XT-1 help needed.
I have a 50” XT-1 with the Kohler engine. It was running normally then this happened; tried to start, just clicking, replaced solenoid, still clicks, replaced battery, still clicks, replaced starter. Engine starts. But blades won’t engage, replaced ignition, cutting deck switch. Still won’t engage. Replaced seat sensor, now the engine starts weather the seat sensor is engaged or not. Bottom line, deck won’t engage and seat sensor has no effect on mower running. Please help.
Old 05-21-2026, 07:00 AM
evhevh evhevh is offline
I would put your old seat switch back in.
I would clean the ground that is in the back of the tractor. Specifically where it connects to the frame. Get down to pare metal on both the wire connector and frame. A common issue.
https://www.onlycubcadets.net/forum/...ad.php?t=63819
