I have a 782 with a bad deck spindle. I got the spindle assy off the deck. Question is how to get pully off the spindle? I know it is keyed so I cant turn it off. I need the pully off to repair or replace spindle. Thank you for the help.
What is wrong with the spindle that you have to remove the pulley? The bearings and seals can be replaced without removing the pulley.
Edit, I am talking about the new style 44C spindles, not the water pump style.
With the spindle in the deck, if I wiggled the blade there was excessive movement. This all started with a loud noise and vibration in the deck. The other two spindles have very little movement. Is there a video around of rebuilding the spindle?
Here is a video of a member here rebuilding his. This deck has the water pump style bearings. Yours could be like this or the newer style.
https://www.youtube.com/watch?v=XKwNaNz9Pvg
Then the pulley should slide off, albeit rust sometimes hinders that. |
I have the water pump style.I pulled the bottom cap. Scraped the rust to get a clean surface and reinstalled. That took up to play so now no slop. The bearing was real smooth. Thanks all for the help.
