Old 04-29-2026, 05:14 PM
Cubcadet782desiel Cubcadet782desiel is offline
Exclamation leaking trans on 782d
I have a 1985 Cub Cadet 782d the transmission is leaking a lot, is it worth putting a different transmission in or resealing this transmission, it is leaking from the two high pressure valves on the bottom of the pump and the weap valves on top, It also looks to be leaking from the trunnion seal And the rear plate seal. And who knows what else beacuase I can't tell because the whole transition is covered in oil. The pickup tube going to the pump is also leaking. Also the back of the drive shaft when I grab onto it it will wiggle up and down in between the two rag joints and I want to get that fixed so I don't damage the pump.
