Old 04-15-2026, 11:41 AM
dcbig dcbig is offline
Default 1572 starter issues
I'm wondering if i could get advise from the "wise ones" hereon about a starter replacement for my 1572.
Should i spend $300-$400 to get an OEM replacement or go with a $150.00 jungle store version...?
Old 04-15-2026, 12:16 PM
CubDieselFan's Avatar
I went with the OEM starter. I found a NOS for under 100.00 a few years ago. What is wrong with yours? They can be rebuilt.
I have a gear reduction on a 1772 and it lasted about a year.
Old 04-15-2026, 12:18 PM
I did have the glow plug upgrade done and a very good ground. The glow plug upgrade helps too.
Old 04-15-2026, 12:20 PM
This is my 1572 when it was restored. Good reading.
https://www.onlycubcadets.net/forum/...ad.php?t=54076
Old 04-15-2026, 01:32 PM
The problem started with intermittent failure to engage; just click or start to engage then spin... Progressed to nothing with the key and just spinning when jumped across the solenoid posts... I figure the solenoid is bad but they cost more individually than do the whole starter assembly...
Old 04-15-2026, 01:40 PM
Where are you looking for the solenoid? They should not be that expensive.
Old 04-15-2026, 01:43 PM
Enjoyed the pics of your b1572 from when Diesel Doc refreshed it... I bought mine at an estate auction in PA; it had 40 something hours on it; 42 if memory serves... It is still less than 50 hours. The old feller who owned it had a snowblower mounted on the front and only used it when there was a snow worthy of blowing so mostly it sat in his garage... That's just taking up space in the shed now; don't need a snowblower in Eastern NC... I'm surprised at the starter issue though, due to low hours...
Old 04-15-2026, 01:45 PM
I'm using my rudimentary online skills to search for solenoids but mostly word of mouth from suppliers i've contacted about OEM replacements...
Old 04-15-2026, 01:54 PM
Do you have a local shop that rebuilds starters and alternators? We still have one but they are getting like radiator repair shops.
Old 04-15-2026, 02:35 PM
I've never had occasion to look for a shop like that but i will ask around. Thanks.
1572 w/54" power angle blade, 1872 w/50" mower deck, 2072 w/60" mower deck, 4' scraper blade and 3 point hitch...
