Old 03-23-2026, 07:23 PM
jbeerens's Avatar
jbeerens jbeerens is offline
Default Starter Generator Oil
I just realized recently that my 149 has the older style starter generator with an oil cap on it. What grade of oil does it take?
Old 03-24-2026, 08:33 AM
ironman's Avatar
ironman ironman is offline
Any oil is better than no oil but I like 3-4 drops of 3 in 1 light machine oil.
Old 03-24-2026, 08:36 AM
jbeerens's Avatar
i don't have any of that unfortunately. How about plain SAE30 like what's used in the engine?
Old 03-24-2026, 05:41 PM
If I recall the ones with the oiler have a bronze or sintered brass bushing instead of a roller bearing. As stated earlier any oil is better than no oil. I think it was originally serviceable.
Old 03-24-2026, 06:03 PM
Sometimes as I have BTDT If the bearing on the pulley side has been updated to a sealed bearing the felt has been removed, so putting oil in it will just make a mess inside. I have only seen a bushing in the communicator end.
Up to 534 and counting...
Old 03-24-2026, 06:23 PM
green407's Avatar
green407 green407 is offline
Bottom of page 3, "8-10 drops of light engine oil every 100 hours"
https://www.onlycubcadets.net/pdf/S_G.pdf
128 X 2, 129, 149, 1250, 1450 x 2
Old 05-31-2026, 01:49 AM
PBIjim's Avatar
PBIjim PBIjim is offline
Back in the 70's I remember rebuilding a starter that had a badly worn commutator and a lot of sticky black powder type crud inside it. It didn't have that many miles on it. The well-intentioned idiot owner (me) liked to lube things a lot, believing that more was better. Apparently, too much oil is a bad thing. It migrates between the brushes and the commutator, then the brush arcs turn the oil into carbon powder and that acts as an abrasive.
A pair of 100's, both look fairly well stock, one with a creeper, and a snow plow that I will never use in south Florida
