Old 03-17-2026, 10:33 PM
jfaison jfaison is offline
Default Carburetor Mounting Stud 782
Good evening,
I need to replace the two carb studs that screw into the manifold of my 782 Cub. The engine is a KT17 and is probably a series 1. I would be appreciative if someone would reply with the part number, specifications or a vendor for the studs.
My 782 needs a little more work than i thought it would.
Thank you for the replies in advance.
Old 03-18-2026, 04:04 AM
That looks like it's NLA. Check with the sponsors above and they should be able to help you out.
The part # is X-352-37. it was also used on other engines such as the Kohler M18's & M20's.
Old 03-18-2026, 06:26 AM
That shows as a 5/16-18 x 1.03 stud. You can probably replace them with some 5/16 - 18 threaded rod cut to length or get something like this from McMaster Carr https://www.mcmaster.com/products/th.../length~1-1-4/
Old 03-18-2026, 06:56 AM
Grandpa53 Grandpa53 is offline
Take one out and take it with you to the local ACE hardware store. I'm sure they can help you out. Most of their stores have a good supply of fasteners.
Old 03-18-2026, 08:20 AM
Any decent auto supply store would have them as well.
I would not go the threaded (all-thread) rod route.
