Old 03-11-2026, 11:28 AM
Jamocha Jamocha is offline
Default Cub cadet 126 front PTO won't disengage
Working in the front PTO of my cub and it won't disengage, from my preliminary research I see that it could be the wear button being worn out, but are there other things that could cause this? What should i be looking for?
Old 03-11-2026, 01:52 PM
Bearing failure, improper adjustment
Old 03-11-2026, 02:12 PM
Billy-O's Avatar
Billy-O Billy-O is offline
What he said.... also check that grill housing is tight, four bolts to frame.
Plow blade
#2 Cart
QA36 snowthower
Old 03-11-2026, 02:19 PM
Could also be loose, worn out, or stripped threads in the adjustment rod.
Old 03-12-2026, 05:43 PM
Check your turnbuckle. It may just need some adjustments or check the cotter pin back by the steering tower to see if it is catching on something that is not allowing it to completely actuate.
