Old 08-21-2025, 10:17 PM
Steve62 Steve62 is offline
Default 3206 Strange Steering Feel ??
I've searched a good bit here and haven't found a similar issue.
The issue is most of the time the steering feels fine and normal then suddenly it feels like the wheel is trying to fight me turning. I can still steer but definitely feel an opposing force with very slight vibration through the steering wheel. Then it goes away, comes and goes.
Everything else is fine, deck lift and 3 point lift as well as the transmission all work normally. Hydro fluid is clean and full on the dipstick.
Could it be the steering cylinder piston O ring failing ?
Old 08-22-2025, 06:21 AM
My 3205 kind of wonders left and right with the wheel held straight forward so I'm thinking it's my cylinder. Does yours do that? If so, here is the company that makes them for Cub.
https://www.customcylindersint.com/p...ering-cylinder
Old 08-22-2025, 08:39 PM
No it doesn't do that.
Thanks for the link, I have a metal lathe so was thinking I would try rebuilding it if the consensus is that's what the cause is.
Old 08-22-2025, 08:58 PM
Maybe the bronze bushing on the steering shaft is in need of lube...
Old 09-12-2025, 09:26 PM
3Kseries4ever 3Kseries4ever is offline
Some have had issues with the rod actually coming unscrewed from the piston in the steering cylinder.
