Old 08-18-2025, 04:15 AM
RideTheSky RideTheSky is offline
Default Broken spring - Slow or no forward movement on Cub cadet lt2 nr92
The spring is broken, reverse movement is ok, forward movement is only if i press the forward pedal a bit, if i press it more or full the movement forward stops, where exactly should be the spring attached?
photo attached
Tags
slow forward spring
