Old 07-24-2025, 12:13 AM
BoShek BoShek is offline
Default Pro Z 160L won't Start - Please help
I have a Pro Z 160 L, 60" with a EZT750 Kohler Confidant engine. It's older, but it only has 185 hours on it. Was mowing my yard about a week ago, everything was fine, and after about an hour of mowing it started to sputter a little bit, so I headed to the garage. Luckily i made it to the garage because after I shut it off it would not start anymore. I can't figure out whats wrong, been troubleshooting for about a week off and on when I am not working.
The engine turns over, has spark (put in new plugs and used a spark tester), and has fuel (I removed the fuel injectors and turned the key and fuel spurts out). I don't understand what is going on, it won't even sputter or fire at all. It just turns over and over.
I have messed with the switches, but i don't think it is any of them because it turns over and has spark, right?
Any help would be greatly appreciated, I am out of ideas.
Old 07-24-2025, 07:15 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Fuel, spark and air (compressed). You say you got the 1st two. What about the third?
Plow blade
#2 Cart
QA36 snowthower
Old 07-24-2025, 07:23 AM
so I hooked up a compression tester to each cylinder, got 0 on one and like 30 on the other, but I didn't think it was legit. I read somewhere that a dual cylinder EFI engine like this probably has a pressure release or something, and also it only has 185 hours on it and it was running awesome now all of a sudden it won't even fire. Won't you lose compression kinda over time and start losing power gradually? would it be all of a sudden and on both cylinders? Do I need to take off the heads and look at valves or something?
Old 07-24-2025, 08:11 AM
Billy-O's Avatar
maybe valves... sticking, bad lifter or bent rod.. Is this OHV? Pull the cover(s) and look see. Did motor overheat due to clogged fins or blocked grass screen?
Plow blade
#2 Cart
QA36 snowthower
Old 07-24-2025, 10:13 AM
I just feel like its something stupid i'm missing...........it was running perfectly fine, it has low hours, no loss of power........... grrr
Old 07-24-2025, 12:16 PM
my grass isn't getting any shorter....... if I dont figure this out in the next couple days I will have to send it out to the mower shop, and that is the last thing I wanted to do, its going to cost me a fortune I dont have.
