new mower for me ( 2017) When she sits after a mow it appears oil is dripping around the oil valve gizmo, looks easy enough to replace , I see no other area it can be coming from
Is this pretty strait forward , looks like tight quarters , and any other ideas where this leak may be originating? Ive ruled out valve gaskets and any block issues Thanks in advance |
Not to be critical of your technical description of the leak origin (HaHa). I believe a picture may help others diagnose this issue
that would make it too easy
Ill get that done
If it the Oil drain Valve from the engine You May Just need to tighten it
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force |
got it figured out, it was the drain valve, who thought it was a good idea to place it where it is on this engine, crazy... but now fixed thanks
You had a valve installed on the oil drain hose?
the oil drain plug is a combination drain plug and valve you turn to drain oil, that in turn goes into a drain hose, dumbest set up Ive ever seen
