Old 04-25-2025, 02:41 PM
sofasurfer sofasurfer is offline
Default Why does center blade not cut very good
LTX1050T. When I mow there is always a longer strip of grass in the center of the deck. Long grass or short. Blades are sharp and not installed upside down. Belt is newer and in good shape. Would the condition of my deck wheels hae any effect on the center blade cut? The rear wheels are seemingly in fair condition. The The front round wheels are worn almost flat. The center roller turns freely. Come to think of it, maybe the round (now flat) wheels are worn so that they make the front roller take more of the deck weight. But then again shouldn't the front roller be allowed to touch the ground since it IS a wheel? Any ideas?
Old 04-25-2025, 05:05 PM
Is your deck tight set correctly? Most mowers have an able they are designed to cut at typically the front is lower than the back. Additionally, most mowers those wheels are anti-scalp wheels and are not designed to ride on the grass nor should they. Every cub cadet product that I have seen requires running at wide open throttle for best performance. The last thing I can think of is, if you’re ground speed is too high your mower will not perform correctly either.
Old 04-26-2025, 11:40 AM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
Have you confirmed the center blade is turning the correct direction
Old 04-27-2025, 11:34 AM
Road_Clam Road_Clam is offline
Is the center spindle original ? Im wondering if the center spindle was changed and is the wrong height ?
Old 04-30-2025, 03:32 AM
Found the problem. Deck was bent at the spindle mounting holes causing blade to not be level, probably from when I broke a previous spindle when I hit an obstacle. Found the solution on this video... https://www.youtube.com/watch?v=2BdllqplWsk
Didn't need the big tool shown as the metal is not that thick. I used a short straight edge across the surface to verify the bend. I placed a block of wood under the bend and wacked it with a hammer. Pretty simple fix.
