Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 02-16-2025, 07:58 PM
Eckenrot's Avatar
Eckenrot Eckenrot is offline
Default 1772 Running rough
I have an issue with my 1772 running rough and blowing black smoke. Seems to only happen after it is warmed up. I replaced the fuel filter and changed the oil but still having the issue. Any advice or ideas would be great!
Thanks,
Old 02-16-2025, 09:54 PM
CubDieselFan's Avatar
Does your 1772 have 2 fuel filters? Does it seem to run better at an idle?
Old 02-16-2025, 10:48 PM
Eckenrot's Avatar
It only has 1 fuel filter. It definitely seems to be running better when it’s at idle.
Old 02-16-2025, 10:55 PM
Is the electric lift pump working good? You should have 2 fuel filters. There should be one on the input of the electric pump and then the paper filter in the fuel bowl assembly.
Old 02-17-2025, 06:52 AM
IHCubCadet147's Avatar
Check the screen on the shut off valve in the tank. I had a similar issue with my 882 over the summer and that screen was blocked.
File Type: jpg 1B5E9A50-ACCD-4B57-B2B6-8557C425B88D.jpg (32.4 KB, 29 views)
File Type: jpg 5DC5EF86-898C-4E0E-A221-BA0B4EAE5326.jpg (34.4 KB, 29 views)
