I am working on restoring a Cub Cadet 122 and the clutch is being strange. I started it for the first time, pressed the clutch down, put it in reverse, and hit the shop wall without releasing the clutch. I am a noob because this is my first cub project and was hoping somebody could help.
![]() Quote:
I think the clutch is stuck how would I fix that?
Well at least the wall stopped ya.
You need to help us out here if you want us to help you. Like what happens when you shift into first? Is the clutch stuck down. So when you turn the key the tractor starts moving. The first place a person needs to start to fix a problem is to start figuring out what the problem is. Start checking out everything you can see and let us know what is going on. Ken |
Maybe this will get you going. Here is a couple pictures of your
clutch. You can pull the clutch cover off and see it under there. Cover is right behind the engine. Start working the clutch pedal back and forth and see what is happening. With the clutch down you should see the tension come off between the 2 pressure plates and the friction disc. Let us know what you see. DSCN2947.jpg DSCN2948.jpg Ken |
Hindsight,put it up on jackstands
If a tractor has been sitting unused for a long period of time,
I have seen the clutch plates and disc all become rusted together. Depressing the pedal will not separate them. If that's the case you can lock the pedal down and pry them loose with a putty knife or screwdriver. |
yep got several old cars trucks and tractors ALWAYS make sure the clutch is depressed when i put them away.
I have had some luck with putting the front of the tractor against a solid obstruction- like the garage wall! pulling the spark plug wire(s) then putting it in 3rd gear, depressing the clutch and hitting the starter. |
Clutch rebuild how to:
https://www.onlycubcadets.net/forum/...ad.php?t=54233
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
thanks for the advise! I will try these things when I get back out to the shop. I appreciate your time!
