Old 10-28-2024, 06:51 PM
KapitanKraut KapitanKraut is offline
Default Newbie Question
Hello, I’m new to the forum but have a question. I have a 14 LGT1050. I was curious if this is a LT platform or not? Can’t find much info on an LGT only LT or LTX.
Old 10-29-2024, 07:32 AM
ironman's Avatar
ironman ironman is offline
The LGT 1050 is a 1000 Series lawn tractor, what I would consider to be in the heavier duty spectrum just below garden tractors.
Here are three web sites you can look up models on.
No single one ever seems to tell you everything about a model but between the three you can come up with decent info....
https://www.tractordata.com/lawn-tra...-lgt-1050.html
https://www.tractor-specs.net/cub-cadet-lawn-tractors
https://tractorgearbox.com/cub_cadet_lawn_tractors.html
Old 10-29-2024, 01:20 PM
Sergeant's Avatar
Sergeant Sergeant is offline
The LGT1050 uses the same Frame as the LT1000, LTX 1000, LT1500 GT1500, and GTX1000 series tractors and several More. The frame was also used for the Troy-Bilt and White Lawn & Garden tractors from 2000 until at least 2015.
683-04469D-0637 is the new replacement frame Number for all those MTD-made tractors, and 683-04469C-0637 is the old Model Number for almost all Belt driven Lawn and Garden tractors made from 2000 till 2015. The Major differences was transmission Model Then cosmetic Hood and fender changes and wheels depending on what the Model was Marketed as
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 10-29-2024, 08:29 PM
Thanks for the info. Was looking for service manual and couldn’t find an exact match. Looks to be LTX 1050 is close enough minus engine and trans breakdowns
