Old 08-08-2024, 02:19 AM
DownNdirt's Avatar
DownNdirt DownNdirt is offline
Default Cub cadet 1000 valve cover upgrades need suggestions
Hi folks, I've been working on my 1000 and have an issue with the breather cover. It's been bowed out and had friends suggest kirk engines' billet cover. Unfortunately he is no longer selling them. Anyone have a lead on a similar company? I like his idea with the hose to reduce oil leakage. TIA
'78 1250, '79 1450, '77 1000
Trapped and released: 124, 1000, 72, 1211
(JD) '70 140 H3 patio yellow, '74 140 H3, '87 332 diesel
Attachments: too much to list
Old 08-08-2024, 03:05 AM
DownNdirt's Avatar
Don't believe I've introduced this one yet. '77 1000 with creeper i bought at a consignment auction for $125 with mule drive. . Only thing I've done to it was new battery, points, air filter, fuel line and valve, and axle seal. Starts good, could use carb flushed as it looked to have sat since ~2018 as it stumbles a bit. Needs electrical gremlins patched because it doesn't charge and driveline fixed as the clutch hub is worn badly ( engine mounts are almost gone so it got solid mounted).
Old 08-09-2024, 01:06 PM
dale c. dale c. is offline
flatten it out and reuse it , shouldn't be oil leakage out the breather just vapors
Old 08-09-2024, 01:15 PM
you will need two gaskets and make sure you put it back together correctly.
There is a drain hole in one of the plates.
