Old 06-14-2024, 09:15 PM
IHCub1450 IHCub1450 is offline
Default Correct Oil Drain Plug Gasket
In the process of rebuilding my Kohler K321 for my 1450 IH Cub, I noticed that the oil drain plug gasket is rotten and needs replaced. I can't tell what type of gasket it is and I've looked in several different spots without finding the answer, so I came here. Hopefully someone on here can tell me what type of gasket to get, thanks in advance.
Anybody?
1976 IH Cub Cadet 1450
2006 Cub Cadet GT-3200
Old 06-16-2024, 01:50 PM
Default Still unanswered
Anybody have the answer?
Old 06-16-2024, 06:20 PM
finsruskw finsruskw is online now
It's just a common 3/8" tapered pipe tread.
Get a plug from any plumbing shop, hardware store or farm store.
That's what all my Cubs have in them for plugs.
no gasket involved.
You must have the original plug with the now rotten fiber gasket
This is what i use.
Old 06-17-2024, 07:47 AM
DSarow DSarow is offline
Make sure you have a good fitting wrench and don't over tighten the plug.I have a 8 point socket which ends up to fit the corners,instead of the two flats,I feel its a better solution
Old 06-17-2024, 09:59 AM
Should I just replace the plug and not get a new gasket?
Or either way is okay?
Old 06-17-2024, 12:08 PM
ironman's Avatar
ironman ironman is offline
I just happen to be changing oil in my 1200.
Here is what i use, just a nylon washer.
Take your oil plug with you to any decent hardware store and they will fix you up.
I also like to epoxy a magnet to the end of the plug to collect metal particles.
Old 06-17-2024, 05:00 PM
Thanks. Good idea on the magnet.
