Old 06-09-2024, 12:25 AM
Possum Possum is offline
Default Carb help please...
1440 with briggs 14 hp.. Cub died while mowing.... diagnosed issue as fuel solenoid wire. Replaced with new solenoid and it started right up...BUT... I'm now seeing gas come from the 90 degree tube at the top in this ...hopefully attached... picture.
I don't remember removing anything from this when I pulled the air cleaner...and I see no tubing to indicated a fuel return line.
My best guess is a vent, but it looks like there should be a tube attached to it so the gas could drain away from the hot engine...but there isn't.
So...
1- should there be some kind of tube attached here?
2- and what would make gas come from this thing...bad float? Needle and seat?
Old 06-09-2024, 01:12 AM
Steve N Mi Steve N Mi is offline
It may have run for a short while on gas from the float bowl but without a gas hose connected to the 90 from the fuel pump it will die. Take another look for a fuel supply hose coming from the fuel pump and reconnect to the 90.
Old 06-09-2024, 01:57 AM
No...the fuel pump comes into the carb on the left side of the picture. The 90 degree at the top is not for fuel coming in... my guess is a vent...but i think it should have a hose attached...and it doesn't.
But my main Q is why does gas come OUT of the 90
Old 06-09-2024, 02:24 AM
Sorry Possum, I don't know the answer to your question then. I thought I could be of some help, appears I was wrong.
BTW, welcome to 'only cub cadets'. There are fellows on the forum I'm sure will have the correct answer for you.
Old 06-09-2024, 06:30 AM
Sam Mac Sam Mac is online now
Pull the top of the carb off, you probably have some crud in the needle and seat. The 90 is a vent you can put a piece of hose on it so that it doesn't leak out on the top of the engine.
Old 06-09-2024, 11:48 AM
What Sam said plus check to see if the float does not have gas in it....
