			I have a 1991 1782 diesel garden tractor that stripped the splines off of the front end of the drive shaft in the CV joint. I was lucky enough to find a NOS from a cub dealer in Indiana. I installed the new drive shaft and upon starting it is making all kinds of racket and I notice a wobble in the rear CV joint at the hydro pump connection. Obviously this is a problem. Does anyone have any suggestions?
			Sounds like a worn rear CV joint. Did you disassemble both joints, clean and check for wear before reinstalling and greasing the drive shaft? Balls and/or housing could be worn or damaged. May need a replacement. If your front splines were damaged, more than likely the rear joint suffered some damage as well.
	How many hours are on the meter? Maybe your 1782 had a hard life?
			Everything is new. I disassembled, cleaned and regressed everything. From the motor output to the hydro I put is brand new. That is why I am completely confused. I suppose one of the new CV joints is bad but because this is now an obsolete part I doubt I can get lucky enough to find another one and $400 once is bad enough. I might have to get creative and fabricate my own driveshaft and use an automotive uoint.
			800 hours on the meter.
	Mostly mowing so not a very hard life.  |
			800 hours isn't much !
			Let us know what you come up with.
