Old 02-21-2024, 08:55 PM
Jb4249 Jb4249 is offline
Default M18 fitted in a Cub 782 fuel issue
I am trying to get a Kohler M18 that I put in my Cub 782 started. I used the wiring diagram that a gentleman on this page showed my and wired in the needed relay. Engine cranks and has spark, try’s to start on spray but I am pretty sure it’s not getting fuel. I found the little solenoid on top of the carburetor and I don’t think it’s getting 12v needed to operate. The wire just goes down into t(e engine, and I can’t find it on any of the diagrams I have seen. My question is can I just splice that wire to the 12 volts that goes hot when key is on?
Old 02-21-2024, 09:44 PM
Yes that should allow fuel to flow into the carb.
You can splice into the wire that originally fed 12V to the coil on your old engine
Old 02-22-2024, 12:30 PM
crazycubtrio crazycubtrio is offline
I’m not sure what machine you’re new M-18 came out of but I never new any of them to have carburetors with the fuel shut off solenoid. If that’s what it has then the key on 12 volt terminal on the ignition switch would have to be used for that
Old 02-22-2024, 01:33 PM
That worked. I connected the little black wire to my 12v from ignition. Picture before I cleaned the carburetor.
Thanks,
Old 02-22-2024, 01:49 PM
Not a problem, glad it worked for you.
Not a lot of Mag 18's had that fuel shut off solenoid, mostly the last of the production run.
