Old 01-01-2024, 12:14 AM
dagenham dagenham is offline
Default 1650 with Johnson loader
I am getting a 1650 with a Johnson loader. It's been sitting so I got it for a good price. It's a bit of a project but not bad. The loader looks to be in great shape other than dry rotted rubber on the hoses and some rusty looking fittings.
I'm not familiar with wide frames and quiet lines. Anything I should be concerned about with these?
Old 01-01-2024, 08:05 AM
mrfred54 mrfred54 is offline
Engine iso mounts are probably bad. Alot of the tin heat shield on the engine is probably rattled loose. With bad engine mounts it will be hard on the drive shaft couplings. Good luck with the project, sounds like fun
Old 01-01-2024, 09:12 AM
How hard are the engine mounts to replace. Lift up the engine a little bit, completely remove engine?
Old 01-06-2024, 07:33 AM
Remove engine from isol mount plates then you can remove the iso mounts.
Old 01-06-2024, 09:32 AM
CubDieselFan's Avatar
Delta Cub is the Queen of Quite Lines. Here is her latest save. Yours probably has some of the same issues.
https://www.onlycubcadets.net/forum/...t=56147&page=2
Old 01-06-2024, 05:47 PM
Farmall450's Avatar
Quietlines are awesome, and 1650s are the best quietline!
