Old 10-27-2023, 08:20 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Default K161 Engine Rebuild Progress Thread
A while ago I removed the engine from my IH Cub Cadet 70 for rebuild. Tonight, I started disassembly. Removed the cylinder head, oil pan, and a couple other things. I’m sure I’ll need lots of help throughout this process as it’s my first time. I’ll be using the ultimate kit from isavetractors.
https://www.onlycubcadets.net/forum/...pictureid=8369
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 10-27-2023, 09:31 PM
For what it's worth. The joy of doing what you're doing is to take
the time to just look, explore and enjoy what was built. And enjoy putting
it back together. Learning is always a good time.
Ken
Old 10-28-2023, 12:40 PM
Jakespoon's Avatar
Jakespoon Jakespoon is offline
It is enjoyable and a bit tedious. And sometimes it doesn’t turn out. Complete rebuild on my 147 engine including sending the crankshaft off to be turned and still ended up with a knock that you can hear standing next to it but not with the stethoscope. I’m working on my 2nd originals k161 now. Busted connecting rod when I bought it. Waiting on a crankshaft and rod.
IHCC original-70-105-124-147-108-1450 running and usable
Projects- Original--72-102-123-100-147-1250
Old 11-22-2023, 08:07 PM
LAWN BOY's Avatar
We’ve determined that this engine has not been rebuilt in the past. I’ll be ordering the rebuild kit this week or next.
Old 11-22-2023, 09:26 PM
Did you properly shim the cam to spec on that 147?
Therein may lie the answer to your knock.
Old 11-27-2023, 08:05 PM
LAWN BOY's Avatar
I just ordered the rebuild kit.
Old 12-04-2023, 08:17 PM
LAWN BOY's Avatar
The rebuild kit is here.
We are not certain as to how to remove this end of the engine(the flywheel and the shown cover and stuff). Can anyone give me some directions please? The videos I found online were either for slightly different motors or started too far into the rebuild…
https://www.onlycubcadets.net/forum/...pictureid=8390
Old 12-05-2023, 06:22 AM
Removal of the yellow flywheel cover is self explanatory after removing the retaining bolts
The nut in the center of the flywheel "cup" is right handed so removal with a socked allows the Aluminum drive cup/screen to come off with some prying, as it is doweled to the flywheel, be careful to remove it flat, trying to not cock it as damage to the cup dowel hole can occur.
then use a flywheel puller to remove flywheel.
Old 12-05-2023, 06:25 PM
LAWN BOY's Avatar
Thanks for the help Ol’Geoege. I am to the point where the flywheel and all that is off. Now it’s just the plate which I don’t know what the name for is. I took its bolts out, but then realized in an attempt to pull it off it moves the entire motor all the way to the other side if that makes any sense. I wanted to remove the other side, but the 3 screws that hold in the small pieces of metal don’t turn out. They just spin.
Old 12-06-2023, 08:01 AM
ironman's Avatar
ironman ironman is offline
This here book, specifically section 10.........
https://resources.kohler.com/power/k...df/tp_2379.pdf
