Can anyone tell me if the ch 18 will go into a m18 tractor or will it be to much time and money to make the swap? Thanks for any unfo.
![]() Quote:
You will need to move the starter wire to the opposite side and add a switched 12 volt for the carb solenoid. As well as a new throttle cable and driveshaft. If going into something like a 1811 or similar you can get a 1863/1864 donor tractor and use wiring, driveshaft and hydro pump and it will be a bolt in swap
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
Thank you thats great unfo.
I have a thread on here swapping a CH into my 1711 (KT17).
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Do you have a link its buried
