Old 07-20-2023, 04:28 PM
cubs-n-bxrs's Avatar
Default 450 &451 gearbox ratios
Would anyone happen to know what the ratios are on the two different gearboxes. I have a couple that I need to sell so I need to advertise them correctly. Thanks Kelly
Old 07-20-2023, 05:39 PM
This what I have on file:
For the 450 it will be 1.87 turns of the input pulley to make one complete turn of the fan.
For the 451 it will be 2.58 turns of the input pulley to make one complete turn of the fan.
Old 07-22-2023, 11:31 AM
Farmall450's Avatar
Fan or impeller?
Old 07-23-2023, 09:37 AM
Thanks Roland.
