Old 07-12-2023, 11:28 AM
Yardman Yardman is offline
Default 3225 travel speed reducing
I have noticed my 3225 is "slowing down" Reverse has always been very slow but forward is now slow. I have seen threads related to this and one common fix is to replace the pedal bushings and adjust the pedal travel. When pressing the reverse pedal I can manually reach down and pull up on the forward pedal and the speed increases. All hydraulics appear to be working fine.
Can someone explain how to replace the bushings or make adjustments to the linkage to gain more speed? Looking at the parts diagrams I don't see any reference to bushings and I don't have a service manual that discusses how to adjust pedal speed.
Thanks!
Old 07-12-2023, 11:57 AM
service manual. scroll down to find it.
https://www.mymowerparts.com/pdf/
Old 07-12-2023, 10:59 PM
Download the book Mr. Lew posted.
Go to the Cub parts look-up in the yellow box above.
Put in your model # and then go to the "Brake & control pedals" tab.
It's been a long time since I have done one but IIRC you will need the quantity it lists for part # 41, 42 & 43.
The speed adjustment is covered in the book but I'd replace the bushings first.
Old 07-18-2023, 11:36 AM
Thanks! Where can I find Mr Lew's book? I looked in the book reference section.
Old 07-20-2023, 03:07 PM
rudedawg's Avatar
rudedawg rudedawg is offline
https://www.mymowerparts.com/pdf/Cub...epair-Manuals/ scroll down to your 3000 series model, there's a ci housing and an alum housing trans.
