Old 06-12-2023, 02:50 PM
hossjesse hossjesse is offline
Default Will a 451 snowblower fit on my 782
I got a 782 and looking at a 451 snowblower. My question is will it fit on my 782 if I have to do some welding I'm fine with that I will never take it off it
Old 06-12-2023, 03:20 PM
Farmall450's Avatar
Why would you have to weld anything? I assume you have the small PTO pulley, so a #450 would be correct (I have a #450 on my 1811/1862).
