Old 06-04-2023, 11:20 AM
knucklebuster283's Avatar
knucklebuster283 knucklebuster283 is offline
Default Kohler CH18 flywheel and coils
I've read somewhere, can't remember where. But I have a CV22S that had the famed smart spark. I also have a CH18S with badly pitted cylinder walls. I can only rotate the crank half a rotation either way. Question is , can I use the flywheel and coils from the CH18 on the CV22. Can't see spending $150.00 to convert the CV22 if everything from the CH18 will work.
Old 06-04-2023, 09:37 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Get the 2 manuals for the engines and compare the part numbers , if they are the same bingo , or as Jackie Gleason once said "away we go"
https://kohlerpower.com/en/engines/manuals
Oz
Old 06-05-2023, 06:57 AM
From the limited information given, and from what I could find, the answer is NO. Different parts.
Old 06-05-2023, 08:43 AM
Frank1541 Frank1541 is offline
There is a decent chance that this will work. The first thing to do is confirm that the CH18 coils and fly wheel will fit properly. Are the mounting points in the same place relative to each other? The electrical part should not be too difficult to sort out. You may lose a little performance without the smart spark.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 06-06-2023, 06:54 AM
I would just swap the coils. Keep in mind that you will need to use the CH18 kill wire setup.
Old 06-06-2023, 09:55 AM
That's what I'm going to do Sam. Can't for the life of me, remember where I heard to use the flywheel also. From what I understand, this will work on CH,V 22's up to the CV23 24's. I think the keyway on the Ch & CV18 is a little off from the Smart Spark flywheels. We'll find out, hopefully will have it running this afternoon.
Old 06-06-2023, 07:15 PM
got the coils mounted on the cv22, and got spark. Got to get a new battery finish cleaning the carb should be good to go.
Old 06-06-2023, 07:27 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
I think you need to use the flywheel also.
They sell a kit to convert that comes with the flywheel,2 coils and wiring harness.
JD x475
Old 06-13-2023, 10:08 AM
I think you may be right. Haven't had anymore time on this as we are heading out tomorrow for 2 weeks in Tenn.
