Old 08-29-2010, 09:37 AM
Hubman's Avatar
Hubman Hubman is offline
Default K301a 12 hp /basic wiring
Going to go look at a 12 hp Kohler that has been pulled from a 127 . It is complete with S/G, Coil,condensor, Gas tank,carburetor. I maybe getting ahead of myself . But what would be the minimum wiring arrangement to get this to turn over and run . Outside tractor sitting on ground .Thanks
Old 08-29-2010, 10:32 AM
From a good hot 12 volt battery, run a wire from the pos. (+) terminal to the "A" lug on the S/G, then another from the pos. (+) terminal on the battery to the pos. (+) on the coil, then another wire from the neg. (-) battery terminal to a good ground anywhere on the engine or S/G (except a moving part or a metal fuel line).
When the engine starts, remove the wire to the "A" lug on the S/G.
Be sure the points wire and the condenser are connected to the neg. (-) post on the coil and the condenser is grounded.
Old 08-30-2010, 07:24 AM
Hubman's Avatar
Yoesmite Sam , thanks for the helpful information . Now just got to take a road trip to look at this motor.
Old 09-05-2010, 11:48 AM
Hubman's Avatar
Default Thank you
Yosemite , thank you . I should actually print this stuff out to read . My memory sucks .
http://www.youtube.com/watch?v=lfuSEie3rHM
