Old 01-30-2023, 09:48 PM
nutzboutoldies's Avatar
nutzboutoldies nutzboutoldies is offline
Default 1450 Starter Solenoid Location
My 1450 is cranking slow and wont start even with battery on charger. I'm wanting to check all of the connections before replacing any parts and don;t know where the starter solenoid is located. I think it's located behind the dash but can't see it to be sure. Can I get to the solenoid by removing the plate behind the fuel tank?
Steve
Steve
1450
QA42A Thrower
44A Mower
Old 01-30-2023, 10:46 PM
Yes it is on the right side when sitting on the tractor.
Old 01-31-2023, 12:06 AM
Thanks for the reply. I thought so but didn't want to start tearing stuff apart unnecessarily.
Steve
1450
QA42A Thrower
44A Mower
Old 01-31-2023, 09:08 AM
Remove the fuel tank & firewall to gain access to that area.
It will all come off as an assembly.
Then remove the panel (2 bolts) behind the firewall.
Old 01-31-2023, 01:10 PM
Thanks for the explanation! I was thinking that was what I needed to do but wasn't sure.
Steve
1450
QA42A Thrower
44A Mower
