Just found a narrow frame hydraulic lift to put on my 125 and was curious as to the reliability of these units. I use this tractor mainly for snow removal with a push blade. The lift I purchased seems to be working fine and the cylinder is rust free. I did drain and fill the pump with fresh Hy-Tran.
No leaks or cracked hoses than you are good to go.
I put a Hydraulic lift on my 125 3 years ago and it's still working OK. I also use it mainly to lift a snow blade although mine also lifts the rear hitch too. I had to replace the hoses as mine were deteriorating on the inside, and there was a bit of a learning curve before I got everything adjusted correctly, but no problems since then.
It works as good, or better, than any 50+ year old piece of used machinery could be expected to. I like it. |
Bought one with the Intentions of Putting it On My 106 But decided I Like the actuator Look so Going to Put this On the 106 https://www.thomsonlinear.com/en/pro...uators/h-track already replace the duff-Norton actuator with a Thompson electric actuator (still to slow compared to Hydraulic lift) But I'll see How Plug and Play Hydraulic work. And Put the Narrow frame Hydraulic Lift Unit On the 70 I Know I need to replace the Hoses on the Narrow Frame Unit as there Look's to be a slight leak. I Know there Original Hoses as well and the Previous Owner Just started Have a slight leak about 2019, and It was On a 104 when New in 1967
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force |
How spendy are those units?
I had a hard time finding one in decent shape by itself, so I bought a whole tractor to get the lift. The donor 125 is not in as good of shape as mine so I will just remove the hydro unit amp put it on my 125.
The electric over Hydraulic actuators I think there In the $600 to $1000 dollar range depending On the Length You Buy
Somebody was selling these https://ph.parker.com/us/en/compact-...aulic-actuator In the $600 dollar range Last year On eBay ![]()
