Old 12-04-2022, 12:19 PM
thadscub's Avatar
thadscub thadscub is offline
Default Wheel spacing on a Cub Cadet 122
Okay, I am having the bearings in the front rims spin, what is the backspacing on a 16x6.50x 8 rim on a Cub Cadet 122? I need new rims.
Thanks,
Thad
Old 12-04-2022, 01:18 PM
Shim them between the bearing and where it contacts the center hole of the wheel.
Always worked for me.
Use thin mat'l. like a tin can or whatever it takes.
This is what happens when the wheels and bearings are not adjusted when installed.
You should only press on the outer race of the bearing when installing and adjusting the runout.
May take some trial and error using machinery bushings so the assl'y does not move laterally (in and out) on the spindle of the knuckle when installed.
And use good quality bearings, not the $5 farm store parts.
Old 12-07-2022, 09:40 AM
mortten mortten is offline
I have used that aluminum duct tape.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
