Old 10-10-2022, 06:35 PM
Kris Brown's Avatar
Kris Brown Kris Brown is offline
Default 1811 fuel pump
So I replaced my original pump with an eBay on because of rust in the original kept plugging up my carb, but now it’s giving me problems. I was wondering has anyone put an electric pump on a 1811 or any model Cub? If so how good does your set up work and what pump did you use. Thanks in advance
Kris
63 CC Original w/ 38” deck and front plow
72 129 50” deck, 42” blade
73 86 42” deck, 42” blade
84 CC 680 w/50” deck and 42" plow
89 CC 1811 46GT" deck,QA42A, 38" IH 1A tiller, Brinley-Hardy plow x2
1982 Gilson Lawn Tractor with 38" deck
Old 10-10-2022, 07:35 PM
A lot of people that go to Electric Fuel Pumps use this one. It emulates the pressures from on the Kohler Pumps.
You simply wire it as follows: Positive Wire to the "R" terminal on the Ignition Switch (or in that circuit). Negative wire to ground.
That's it.
Old 10-10-2022, 10:03 PM
Farmall450's Avatar
That's it.
Yeah, it's getting hard to find a good mechanical pump. I have swapped the guts from the last new China one and kept the rod/body of the OG pump w/ success.
Old 10-11-2022, 08:08 PM
The fuel pump is not needed on an 1811 if you keep the tank above 1/3 full……and your not ditch mowing
Old 05-23-2024, 06:37 PM
Mayorchuck Mayorchuck is offline
Reviving an old thread here. My 1811 is acting like it's fuel staved. Looking at the line from the tank, it goes to something bolted under that crossover pipe. Is that the fuel pump? I've been searching for info on the fuel filter without any luck. Ran out of time this afternoon but hoped you could help save me from digging for something that's not there. Thanks.
Old 05-23-2024, 09:24 PM
Here is a look at the fuel pump. If you pull the outlet side of the
pump and crank it over you should see fuel coming out.
Anytime I am suspicious of things starving for fuel. I go to the
beginning of the system (the tank) and clean my way forward.
It resolves a bunch of issues. Some we don't even know we have.
And you learn a lot as well.
Ken
https://www.cubcadet.com/en_US/conte...d862bad35828/y
Old 05-25-2024, 08:46 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
Did the same..
Don't forget to check the screen at the fuel valve. It can get full of junk. Make sure the valve is fully open.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 05-25-2024, 02:04 PM
I'm running one of these POS's on my 3205 for 3 years now and so far so good.
https://www.amazon.com/Universal-2-3...48&sr=8-1&th=1
I just purchased one of these finely built units for an 1811 I'm sending down the road. It seems to work okay so far.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 05-27-2024, 11:53 PM
Thanks folks. Just getting back to this late this evening. Looking at what few photos/vids there are on this model, I see a previous owner removed the filter. I just have a straight line from the tank to the pump. I also discovered the forementioned fuel valve. It was open all the way. I think I will order the stock fuel pump, put a filter, new hoses and clamps on it and see where that gets me.
Thanks again for taking the time.
Old 05-28-2024, 12:05 AM
Ken
Will try this tmro before I order the pump. Thanks.
