Old 08-28-2022, 07:17 AM
wkentw wkentw is offline
Default Hydro gear fill plug stripped
Morning folks. I have an '08-ish RZT50 with ZT-2200 hydros.
Hydro - zc-dmbb-4ddc-2rpx
I'm trying to fill the hydro but the fill plug is now stripped. It's 1/4 hex. Any ideas on getting that plug out?
Old 08-28-2022, 08:33 PM
Farmall450's Avatar
Heat, drill and extract.
Old 08-28-2022, 08:52 PM
Weld a nut on it if if is not aluminum or brass, and unscrew it.
If aluminum, Heliarc it, if brass braze it.
it all that fails put in an EDM machine and arc/burn it out.
If that fails put it in the mill and drill it out.
Next time use a new Allen key BEFORE you feel it trying to round the hex out
Old 08-28-2022, 09:47 PM
Thanks y'all. I got it out.
I removed the hydro and got it on the bench, then just hammered in an allen wrench AND put a small vice grips on it. It came loose. But it's still mostly stripped. So I'll be ordering a new one.
Thanks again.
