Old 07-25-2022, 01:13 PM
tweivoda tweivoda is offline
Default Lost my lights on my 1862
I replaced the halogens headlights with LEDs this past winter and they worked fine until this past weekend. I didn't have my circuit tester available and I forgot to check to see if I had tail lights.
Are the lights on the 1862 fused? If so, where is the fuse located.
Old 07-25-2022, 01:35 PM
There is NO specific fuse for the "light circuit".
Power comes out of the "L" terminal to feed the Head & Tail Lights on the blue wire.
If you have lost both head & tail lights, then I would look at the Ignition Switch. If you only lost one, then I would look for a broken wire.
Old 07-25-2022, 05:49 PM
Farmall450's Avatar
The halogen lights are also good for burning out abruptly, if you find power to the light but no light. Maybe the LEDs also suffered that fate?
Old 08-21-2022, 08:23 AM
The light problem was fixed. The LEDs failed so I went back to the old halogens I took out. The LEDs had less than 30 minutes of use so I am not sure why they failed so quickly. Both failing at the same time makes me think there was a current surge or a short of some kind.
Oh well, since I don't use the tractor much after dark I think I will stay with the halogens.
