The roll pin that attaches implement handle to the rod which lifts the mower deck has sheared off. Does anyone have any advice how to get the roll pin removed. Will i need to removed rear fenders in order to pull off the handle?
No.
Remove the 4 foot rest plate screws. Then pull the front of the pan away from the frame, it will flex that far, and block it with a 2x2 piece of wood against the frame. This will give you enough room to get the handle off. Replace the pin with a new 5/16" Spirol pin, not a split pin or a bolt. Best to have a set of roll pin punches for this task Good luck |
Thanks the process explained worked perfectly!
