Old 04-20-2022, 02:14 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Hydraulic Fluid and Hydro fan for 149
Has anyone used Travellers Hydraulic fluid for their IH 149? If so, any problems? Does the Fan on the driveshaft pull air over the pump from the rear to cool? Is the fan mounted with the locking ring facing the pump or the engine? Thanks in advance for your help and have a great day.
Bob
Old 04-20-2022, 08:39 PM
ironman's Avatar
ironman ironman is offline
Bob
I have used it for years with no problems, but I change it every 2-3 years.
No, it blows air over the hydro cooling fins from front to back.
I forget.
Old 04-20-2022, 10:28 PM
I can't remember either, but the fan needs to blow rearward as mentioned, so the radius of the blades (lift if it were an airplane wing)
would be on toward the front of the tractor
And I also use tractor supply's universal hyd fluid.
Do not use anyone's "303" hyd fluid.
You can also use automatic transmission fluid type"F" as specified by the hydro manufacture, Sundstrand.
Old 04-21-2022, 11:14 AM
ironman's Avatar
Mr Bob, maybe this will help....
Old 04-21-2022, 03:02 PM
Mr Bob's Avatar
Default Fluid and Fan
Thanks to all that replied to my questions and thank you IronMan for the picture. I have trouble visualizing things now and that picture really helps.
Everyone have a great day.
Bob
Old 08-16-2022, 05:08 PM
SuzukiT350man SuzukiT350man is offline
Bob
My 129 hasn’t had a fan blade on the driveshaft for years and it hasn’t had any issues. The only problem with my trans is that one of the fluid lines got bent by a stump while hauling firewood on my property, and it leaks a small amount when it’s sitting. The fluid that’s supposed to go in the trans costs a pretty penny and I’ve been filling it up with travellers hydrostatic fluid for a while now. I don’t recommend doing what I do, but after carrying dozens of cords of firewood and cutting 1.5 acres every week during the warmer months it gets the job done
Old 08-16-2022, 10:13 PM
Tom Dowling Tom Dowling is offline
ironman that picture looks like a brand new cub, how do you keep it looking that good?
Old 08-17-2022, 09:10 AM
ironman's Avatar
That picture was from when I did a total resto on it about 10 years ago,
it doesn't quite look that good nowdays....
Old 08-17-2022, 09:34 AM
149Chris 149Chris is offline
Default Fan Location on drive shaft
I just did one so knew this picture & text are on page 2-39B of the service manual.
File Type: jpg Screen Shot 2022-08-17 at 8.29.03 AM.jpg (25.7 KB, 163 views)
File Type: jpg Screen Shot 2022-08-17 at 8.29.26 AM.jpg (19.9 KB, 163 views)
Old 08-17-2022, 10:56 AM
RoseHillFarmIHCC125 RoseHillFarmIHCC125 is offline
Ironman that’s a great looking machine. I wish mine still had factory IH size tires.
File Type: jpg 0494BD89-2684-4612-82CE-19A685E2193E.jpg (34.0 KB, 163 views)
