Thread Tools
Display Modes
bought this in 2010 , 11 hard seasons and just didnt want to have to rely on it for another year so i bought a ST 54 and started fixing the GTX 1054 up thinking i would useit without a mower deck for tool caeting and small jobs where the tractor isnt necessary
put new starter , battery , plugs , air filter kit , oil change , new zerks , drive belt , idler pullies knew it had a oil leak developing but honestly thought it was the seal on the filter , and it was negligible so i wasnt over concerned there was no oil on the old belt , i dropped the PTO and the drive pully to install the new belt and no oil on the drive pully or shaft either so not a seal i do not believe however the oil is pooling on top of the PTO pully after the oil change i pressure washed it inside out and underneath , i let it set a day and there was fresh oil pooled on top of the PTO pully again , not the oil filter still plenty on te dip stick so its still not gushing it but i cant figure out where its coming from sound familiar to anyone? |
I've seen this a few times.
Check the plastic oil drain is screwed into the block nice and tite. Only other place is the bottom crank seal.
JD x475 |
![]() Quote:
as for the crank seal im very certain i would have had oil all over the drive belt and the drive pully when i installed the new belt (old one was cracking) , the shaft was bone dry you made me feel better by giving me a new thing to look for , i was worried i had a cracked case or something , but its a very strong 27 HP Koehler so im not leaning that way hence the baffled part will keep you updated |
![]() Quote:
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
thank you , will try and have a look tomorrow , fingers crossed , i just put full syn oil in it
Well, I finally got a chance to have another look. The pooling HAS STOPPED. None on the pulley, none on the floor, and oil level correct on the stick. I am perplexed to say the least.
The PTO pulley where the oil was pooling on top of, was bone dry. I'm at a loss. |
