Hello
The evaporation line (permeation line?) has rotted off both ends (top of tank and front of engine. Where is the connection to the front of the engine for this line? Do I have to use a specific kind of hose for replacement? Thanks, and thanks for your patience with dumb questions. |
Welcome to OCC..........
Most here are not familiar with that new of a mower. It would help us if you posted a few pictures of the problem.
More importantly, there are many variations of the XT1. I've seen some versions of the XT1 showing the evaporation line being 3/16" ID and 51" long and available for about $12 to $13 plus shipping.
Look at the link above "Cub Cadet Parts and Service Look-up" and then click the square in middle of page then enter XT1 in the model search query.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
What engine is in it?
Should go from top of fuel tank to somewhere between the carb and air filter. If it's a kohler engine you'll need to remove the engine cover and the 2 nuts holding on the filter housing. Should be a nipple there somewhere.
JD x475 |
Thanks for the responses.
It is a model 13APA1CT056 Kohler 7000 series, KT725 Looked up the parts diagram and i don't see where the evaporation line connects to the front of the engine. In look at the engine, the only thing i see there is a small "nipple"?, extending down from the bottom of the air filter housing. No barbs on it, just a smooth projection, that would fit the hose. And, what is this? Number 1? |
According to the diagram it is called:
1 KH-25-173-09-S Masking Cap |
This is what the kohler engine folks says it looks like. But what is the purpose?
forgot the pic
Looks looks a cap
JD x475 |
